THe NAC Lots-O-BFG KO2 Thread
Are you really gonna notice a difference of a few mm? A tank of gas changes the rear suspension height more than that.
My jeeps usually have the "dog with hemorrhoids" stance, a little extra lift in the front helps
uh metal is not some uncuttable material like your mom
News to me, I could never get my zig zag scissors to cut through this steel plate I've got. Figured it was impossible.
If you need an upgraded fuel pump for whatever reason Dave, I still have the Aeromotive Stealth 340 I ran in my MJ for a bit.
$100 and it's yours.
Bolts into any XJ/ZJ pump assembly.
It's $1250 for the blower and what I'd need (assuming it came with the pump) and I'd guess another $1-200 for used injectors (if my 24 pounders don't work), then who knows how long my tranny would last. I'm sure all the other little shit (boost gauge, shift kit, etc) would add up quick too. I'm probably not going to drop what would end up being several thousand on that when I can go out and get something that's actually fast.
If I see the need for an upgraded fuel pump with what I've got done for bolt ons, I'll definitely let you know.
It has thermostats that measure the temp of your taint. Once it hits anything over a 30% swass saturation level, it kicks down the heat a few degrees. The only bad part is that it measures in celsius, which we all know isn't real.
*** out your house bro get them bling aftermarket T stats that Dave's got.
thermostat chat. my fav
Yo travis check out this bling chrome thermostat
You know what they say, chrome don't get you home, but if your house be chrome you get mad dome.
There's even house icon on the menu in case you forget you're inside a house
