97+? I got one off black jeep. its the flat plug style.
got $20 credit on my autozone card gonna do a complete fluid change in the ax15 tomorow and try to finish up the brakes in the truck, then bring the car in for 2 new tires, should be a fun day.
I imploded your muffler.
yeahh!!
I'm just gonna get a cheap summitracing turbo muffler. Maybe quiet it down a bit at idle.
I don't want to spend big money on the exhaust on this thing. I only have like $150-200 into it tops right now including headers/gaskets and shit.
3" is not big enough but it's all I could fit.
im debating what I'm gonna do.
either build a downpipe to a single 3" exhaust, or make my 2.5" duals work.
so far I just have a little bit of the factory y pipe at each manifold and I picked up a couple cheap flex joints.
As far as ability of an exhaust system to flow enough air for a given amount of horsepower without causing significant back pressure, this is from one of David Vizard's books:
1. For avoiding significant restriction from back pressure, the pipe should flow at least 2.2CFM per horsepower produced.
2. A straight pipe will flow ~115CFM per square inch of area (using inside diameter of the pipe)
Mufflers usually won't flow as much as a straight pipe of the same inlet/outlet diameter, so you have to factor that in, also.
Just trying to save you from doing something twice.
If you can legitimately get over 400 HP, I would think you'd want more than a 3" single.
A rubber band to hold it down and you'll be good.Will flappers help with back pressure?
