MoparManiac
- Amherst, NH
Cool beans, makes sense.
Carmelo, Rock Auto has injectors for $50 a pop.
Shut up Colin, I liked it better when you didn't bring silly dissucions in here.
PS, I have your two sticks of tubing if you wanna swing by and grab them sometime.
He can get a new car for less than that
So you'd like it better with nothing to read and this thread dead? Sounds boring. Just like your build thread.
Sure, unless you want to drop them off. I have no way of hauling 20 ft sticks right now. I'll buy you 99 at the next M&G. Speaking of which, you guys want to do one this coming Thursday?
Like is it more of a ratio than something you want to completely diminish?
What injectors do you need, any stock apps for them? I have a JY run to make sometime today probably.
I might be down for 99, not sure.
sure. i need to grab some stuff from people.
It's a ratio to an extent, but it's more about having more control over the movement of the sprung mass, and easier suspension tuning as a result.
The shocks and springs rely on the sprung mass to act against the unsprung mass. When a 1000-lb Dana 60 hits a whoop and shoots up it, if there's not enough inertia to the sprung mass riding on top of it to counteract that, it just pushes the sprung mass upward as well instead of compressing the shock/springs.
You do reach a point of diminishing returns eventually, as at some point the sprung mass has enough inertia that whatever input the unsprung mass tries to give it won't accelerate it fast enough to matter. That's the reason why those gigantic XXXXing box truck things can haul ass through Dakar...the truck has enough sprung mass to it that the inertia of the body keeps it pretty stationary while the axles & tires do work underneath it...although it still requires a shit-ton of damping just for the heat dissipation. That's a lot of energy being absorbed in the shocks.
This is one reason why I wanted to try the TTB thing...the driver's side (heavier) arm can be easily picked up and carried around by one person, the diff is aluminum, and even then, only half the weight of the complete assembly contributes to the unsprung weight. So in that case, my 3,000 lb lil race truck has the possibility of much better suspension control than a 3,000 lb XJ with a few more hundred pounds of axle floating under it.
Since I worked a bunch of overtime this week, I can use it to take an extra day off next week instead of more money.
Not sure which I'd rather do at this point.
I could use the extra day to haul ass on the MJ.
speaking of which you gonna be around tonight? I am in a stupid hurry about that battery traysure. i need to grab some stuff from people.
chevy injectors?!?!?!?!? your dad is gonna kill you!I think 87-93 350s should be what I want. Basically any 350 that has TBI on it, just take the whole thing if it's cheap enough.
Sounds righteous.
[literal]
So what you're saying is the fact that my drivetrain is adding a lot of weight is a GOOD thing then?
[/literal]
:laugh:
my full frame is a racing improvement :dunce:In a way, yes. That's part of the reason why my XJ got by as well as it did...because that 1200-lb premium I carried over everyone else was all sprung weight, and with basically the same axles & tires as everyone else, the body had more inertia to keep going in a straight line rather than get tossed around.
