OK, something to talk about.
I'm contemplating link material choices. 2" 7075 aluminum vs. 2" x .25 DOM.
The aluminum weighs half as much (would work out to roughly 10 lbs difference per link) and costs 1.5x more, but cost isn't really a concern. The 2" heat-treated 4340 links from HereticFab are also interesting but I think even heavier.
I don't think this rig is going to be heavy enough to damage either material. 2" x 3/16" DOM is also availabile and is about on par with the aluminum weight, I don't know if I'd like the thinner wall though and makes for a non-standard tube adapter.
Depending on clearance issues up front, I may end up running radius arms (gasp). Thoughts on how to do this with aluminum links? I don't really like the idea of aluminum link tabs welded to it; seems like they'd deform too easy. Some kinda clamping sleeve might work if there'd be a positive way to keep it from sliding.
If I do manage to fit parallel links up front instead of radius arms (and definitely for the rear 4-link), I'd probably want to run aluminum uppers too. 2" is probably overkill here. But then I think of those goofy aluminum tierods and I don't really want my triangulated upper links acting like spaghetti noodles and springing back (even though 7075 is a different alloy than those tie rods use, I think).
I have the capability to drill & tap the aluminum links myself which would help to offset the additional cost by not needing tube adapters.
Just thinkin out loud.
