5spd_xj
<<the good ol days
- Dracut, MA
you're a fag, but a positively SPLENDID fag!
awyea? how big is 15 lbs? I'm a dummy but I'd like to have some kind of OBA for trail emergencies if nothing else. re-setting a bead mostly... if it'd work for that then bring it to me at the fest of NAC and I'll tousle your hair as a sign of thanks:sunshine:
billy, what you doing saturday?
welding new floors in maegens jeep. why?
justttttttt wondering, i can already tell im going to be bored. I was thing of heading out west on the bike, or some where lool...
dumb question
in the door o my jeep.
the little tweeter thing makes noise but the big part of the speaker dont= get new speaker? it works if i kick it sometimes, but not anymore
Might do some fishing in the PM if the weathers nice
Sounds like a bad/loose connection somewhere. Pull the speaker out and see if a wire is broken/breaking? If so solder that shit back together. If not then just replace the speaker.
This. don't just check the wires at the speakers themselves. check inside the door, in that rubber loom, and behind the kick panel where there are connection IIRC.x2. The wires in the rubber loom always break. Check that.
thats what i thought, but everythings connected. oh wells
IIRC on the sidewall of my red labels it says that they are radial? which I thought was interesting. I'll have to check them again
Keith is on fire this week!!!
hell, just have a mouthpiece come up to the steering wheel and blow into it when you want to be locked.
called ruffstuff, got my order changed around...
Is it Colin-esque because it is fuzzy or Ross-esque because it's parts sitting idle?(pic removed)
(colin-esque pic)
lookie what decided to show up
Do you have the FF version Adam? I got your text but forgot to ask that.
Not sure if the tube size differed between the SF and FF versions.
I gotta call RS AGAIN and throw a hissy fit AGAIN right now. Over 3 weeks without my order. D-bags.
