THe NAC Lots-O-BFG KO2 Thread
I would bet they would last nearly as long as new ones with the advantage of being a fraction of the price and be able to be swapped out with a quick tug. By the time you mess up one or two sets you'll probably be in a position to get airbumps. Thus, why I said if you ever plan on getting airbumps why put alot of thought and money into a temporary setup?
I didn't think timbrens were that much money?
DOM is free, I already have it.
I agree with S10s out back like you did up front.
Then snag me some.
Why waste time putting in junk bumps if they're going to disintigrate within 5 minutes of me wheeling?
I have free stock front bumps if you want em...
colin:
these are what i run at all 4 corners and they are sexy
and now come in blue apparently
These are small enough to fit in the coil. -stock gmc truck bumps
attachment.php
These are awesome and I use them if you can fit them(easy if you have leaf springs)
Carmelo, can you snag me a set of those next time you come across them?
Does the lower can part separate from the bump? AKA does it just clip in?
My bumpstops:
Rear (I'm sure everyone knows this) modded old fox shock body with these: http://www.summitracing.com/parts/ENS-9-9101R/ so I can/could swap them out for airbumps with 2 bolts at a later date.
Cost? <$10
Front: Hockey Pucks+Timbren A180-65s
Cost? <$90
If you have the $300-400 to swing grab some airs do that, otherwise my setups seem to be working alright.
Also, if you decide to go the GM route IIRC there are two styles of the GM bumps. One for the heavier trucks (yellow "jounce") one for the lighter duty trucks.
It just pulls out so if you did mess one up you can pull it out and replace it. If you wake me up on sunday with a phone call i'll grab two of each and it'll probably cost $10-15 and you'll have trail spares.
Sounds good.
I'll wake your ass up on Sunday.
All you idiots can spend good money on a piece of soft material glued to a piece of sheetmetal, but I'll run these. It's even cheaper than Bill's solution, don't have to pay for shipping, and is "progressive" to boot. Leaving the rest of you having to SUCK MY DICK.
*unless you have airbumps
wendys new fries suck
