THe NAC Lots-O-BFG KO2 Thread
I might have to side with Anthony for the pure fact that it depends on how he has his crossmember/driveshafts set up.
Probably going to need a longer rear driveshaft/shorter front. Not that shortening a front driveshaft takes very long.
If he has a stock crossmember, just move it forward and it should be fine I think?
true. Fortunately for the MJ swap I gotta shorten both.
Actually, anyone got a stock 5spd front driveshaft and need an auto one? I have an AW4/4.0 front shaft I can shorten but if someone else needs a longer one or has the wrong one it makes it easier.
yeah, but when you did the swap, you just put another aw4 in, right?
The list of stuff to do is fairly long. Did you forget about mounting the clutch pedal and installing the clutch line with piston thingy? I agree that just bolting in a new one would be a quick job, but I think there's a lot of overhead that would go into making everything work.
Yeah, though bolting junk in really isn't hard. I hate working under the dash but it doesn't take very long.
Ken, I have the fairlead.
I'll bring it to work tomorrow.
:thumbup: awesome, thanks!
The snow is nearly covering the windows... only about 1 foot open at the top. The drift by the building is taller but it dips down when it gets close to the walls from the wind.
You can borrow it for the low low price of $13.99 :D
Just holler when you need it, nbd.
I hate katy perry's music. however, I don't mind pictures of her
yeah. except you guys suck for mentioning her name because now teenage dream is stuck in my head, whereas at least when anthony mentioned heidi klum, i thought "supermodel".... way better reaction than "ohh, she's hot.... 'you. make. me. feel like i'm livin a. teen. age. dream...'"
see what I mean. So overall, I can totally say that I hate Katy Perry
Stream of conciousness here: I'd like to see a pic of Ke$ha makeup-less.
her music is more bearable
http://www.cutsomething.com/#/home
Go here, go to the warehouse and test lab tabs at the top, then go to the bottom right and click 'get my free blade' if you want a good free sawzall blade.
clothes can be considered a form of makeup
I'm saying you all wear makeup, no implication that I wear any such thing is involved
