THe NAC Lots-O-BFG KO2 Thread
whenever you say sams i get excited thinking you are talking about me.
but then i read the rest of the scentence and realize its not about me
hahaha, if you had a junkyard I would patronize it.
Ross, 97-down or 98-up? Only difference is diameter of the OSS mounting hole.
:roflmao:
told the guy with the audi that just blew up he should buy that first one.
(it's the same guy I convinced to buy my 91 MJ, which I then bought from him)
Oooh, that first one is very tempting. starter is simple, i got a whole front clip out in my shed so grill is no problem, AND it's a 5-speed HO. Exactly what I was looking for a couple months ago. Keeping that tab open, may call him later.
Edit: Oh and the front bumper just went on w/o any problems, all my measurements were right. :party: I really wasn't expecting that. Now time to go pull out the oxy/ace and melt some 4"x.25" angle into twice as much 4" flat stock :thumbup:
off to hd to get another grinder, the finish cleanig up the 60, then it will get new metal on it
I thought you were buying ZF axles :looney:
:smsoap: anyone know somewhere to get a oxy tank filled on a saturday?
I knew I was low but it just ran out on me. Thankfully it ran out right as I finished the long cut, the rest of the cuts I need shouldn't be too bad w/ a grinder.
Hmmm don't really have any spares for that :(
Off to lowes... you know its a big engine when you need a 5 gallon pail to do an oil change.
Just bought one of these.
Does it shoot real bullets or pellets/airsoft?
Also, I went to do my oil change (22 quarts, OW) and discovered the tie rod on the massivemobile is bent. I'm not sure if I bent it, or if it came that way, or if it's supposed to be bent to clear the diff. Anyone know?
Real bullets.GSG-522, its a .22 so it will be nice and cheap to shoot.
Am I remembering right that someone asked if anyone had an 8.25 yoke at some point earlier this wk? I feel like I saw that and said I had one but I can't remember who asked. I just pulled the yoke of my 8.25 and it's free to whoever needs it.
And that's pretty sweet, def should be good cheap fun. As soon as I get my LTC I will probably be driving out to smith and wesson in springfield and picking something up. IIRC they had a .22 bullpup that I was looking at a few years back, I was thinking that would be cheap/fun.. Now I was looking into one of these , could also be fun.
I ended up with a 95 XJ 4.0, AW4, np231 and blah blah blah. If you need anything I posted a for sale thread. Im getting rid of this by next week so everything cheap to go.
i wanna say bob needed it
Alright, for some reason I thought it was carmelo but i had no clue. Hopefully this post doesn't get buried 4 pages deep too quick :gee:
edit: just found a friendlys watermelon roll in the freezer. :thumbup:
rockauto screwed me over for the first time :flamemad:
got the MJ's entire exhaust out (well, from the cat flange down) and installed a new trans mount and a new exhaust bushing at the crossmember. Only broke one bolt on the crossmember and it was one of the 4 "extra" ones added for the improved bracing/mounting on the MJ, probably because the whole thing was saturated with motor oil for the last 8 months. Threw in a new flange gasket, put the cat back in (it was in nearly perfect condition!), went to put the muffler on it and... SHIT! OD of muffler inlet was the same as OD of the cat outlet. Welded up a new rearmost exhaust bracket for the tailpipe, hung the tailpipe under there and called it a day... 4.0s suck with no backpressure. Hopefully I'll have a new muffler by midweek and can just throw it in there and be done with it.
hmmmmmm. checking now.
