THe NAC Lots-O-BFG KO2 Thread
colin, i've got a meeting now but i'll find you a link that explains everything later.
NP
trying to spray laquer in this humidity/heat blows.
That blows.
imma gunna pick up a new tranny mount and start to build the first crossmember this afternoon maybe.
PIX
i put $1100 into my account yesterday, time to order stuff.......:firedevil
:thumbup:
I'll probably be real busy for the next 2 weeks on weeknights at least so we can handle the wheels as soon as we both have some free time. I'm in no rush at this point as the drivetrains not even in yet.
whos coming to the car show tonight?
<- this guy
really hoping it doesn't rain so I can drive the massivemobile there (driving it in the rain sucks with no roof.) I'm also fairly worried about getting it into the lot without running over anything, it has like a 40 foot turning radius and those lots are pretty tight and full of very expensive vehicles and people.
EDIT: if you guys who are getting there earlier can block off like 6-8 spaces in a rectangle at the end of a row (i.e. 3-4 sets of back to back spaces) I can pull in pretty easy and park down the center, then there are like 4-6 locations for people to park on tires.
im in weather dependent
i hear its supposed to clear up
and i wanna see if i have 42" of flex
might have to air down for this one...
likewise...
I have joined the "rag top and round lights" club, but it's ok because my hood is bigger than the roof on a wrangler
Ive gotta fix my pinion angle. Anybody know where the cheapest 4deg shims and pins are?
Could always grind off your perches, pick up some new antiwrap perches, and weld them on at the correct angle.
Depends on if you have the tooling or not.
Cheapest shims I'm not sure on. I got mine from RE a while back. PM FullsizeXJ on here for a quote.
whatever you do
don't cheap out and get aluminum shims.
whatever you do
I don't get this.
I ran aluminum shims in mine for a year and half. Gave them to Josh (masswrecker) along with my leaf springs and they were still in good shape?
I understand the chance of corrosion and all that and I wouldn't do it again, but still I never had a problem.
Yea i heard things about aluminum shims... it makes sense because aluminum isn't very a very good material for high compression loading, especially cyclic compression.
Colin, i'll PM him but why? Can he get them cheap or something?
i've got a set for sale. $20.
I don't get this.
i've seen them shatter into a million pieces just like a steering box spacer.
I don't get this.
well i guess you wheel like an unborn fetus then:looser:
but i have seen them get flattened. and worse, crack and fall out.
Please tell me you've seen my short flight into the troposphere with my XJ at NACfest. You would be proud.
I'm hoping to leave the stratosphere with my MJ. I think that's a reasonable goal.
