THe NAC Lots-O-BFG KO2 Thread
I'm going to throw metal at the Jeep until it makes a bumper for itself. And BTW, my rear bumper is going to use 9 bolts each side :D
Sexy sexy time!
[pic removed]
Nice!
nice, looks like you're another person I can put on the "don't even try to follow while wheeling" list :roflmao:
As long as your drivetrain doesn't sound like it's going to implode then explode I'm sure we can get you though... kinda. ;)
I wish it was the weekend...
I need to get my *** in gear and finish up the front crossmember and hopefully start the inner rail plating.
Me to.
Yes. You do.
http://southcoast.craigslist.org/tls/1864295875.html i know it's only a benchtop... but it's cheap. should i get it?
If you don't have one, yes. For $40 it is way better than a hand drill if it works. Then save for something nicer down the road.
Only if those nine bolts have no dash markings on the head. :gee:
goals for this upcoming weekend
make trans mount spacer
redrill crossmember
make brackets for frt 60
get stuff mocked up on rear 60
My drivetrain sounds much better now... it is presently my exhaust that is making worrying noises. I knew it was on its last legs when my friend bought the MJ in the first place though, since one of the exhaust hangars had rusted off and been replaced with 10ga copper wire twisted through the frame and around the leaf spring...
Oh yeah, guess what I forgot to do? Drill holes for the hitch. The one thing I really had to remember... :doh: guess I'll be drilling them from below and spitting out metal fragments.
Anthony, if you don't buy it I want it!
i already emailed.
yeah, that's what i was thinking too...
keith, if it's held on by 9 1/4-20's it doesn't count.
i already emailed.
What about 9 #10 UNFs in grade 12.5?
Think I can do with out the dry wall screws to shave some weight? I don't want it to have so much weight that the ass end doesnt fly as high as the front. I want a level flight.
redrill crossmember
forgot to add
pull spacers from dd
trade rear mj shocks for frt xj shocks
I've gotta figure out a way of tying/anchoring back my e-brake line from rubbing against the knuckle on my drive shaft... any suggestions?
