foxwar71
- Foxboro, MA
all you need is a stroker with FI
touche.This is coming from a man that tells naxja every morning when he wakes up?:wave1:
Is it bad that I'm already tempted to mod my truck?
I'm going to try and fix the airbag compressor this weekend, that way I can buy an ARB for the rear. Only problem with this is...if I want to step up to H2 takeoffs then I'll prob want 3.91s - 4.10s...and right now I have 3.54s. The carrier break is at 3.73 for a D80.
Also going to get the 3 pod a-pillar gauge with isspros (FP, EGT, and boost) and then get some factory tow hooks for the front.
i went to HF for the first time today.
everybody in MA vote today?
brown FTW
i wanna know how they are able to make even the simplest things suck? i bought an anvil from them, FIRST hit with a hammer and i dented it.
how do you screw up making an anvil? :dunno:
i bought $40 worth of grinder, cutoff wheels, and flapper disks... they had 24 grit flappers. i bought them just for kicks. if they work well, sweet. if not, i only wasted $2.47
http://naxja.org/forum/showthread.php?t=1018741 i like this crossmember. i would have made the notch narrower, though
