THe NAC Lots-O-BFG KO2 Thread
my uppers and lower are in, hardware store didnt have the right zize bolts for the uppers, they were either to long or to short, so i just re used the stockers, no i just need to find my drill so i can install the jks trackbar
sweeeeeeeeeet
I didnt know if it was cool to throw up names, how about initials? If not delete. It was OFR. It wouldnt lock in the disco side and the Tru-trac didnt help giving me one wheel when I didnt need it. I fixed it when I got home but I was going to yank it out until I sold it to you and you did it.
thank god we had an officer of the law there who knew how to use a fire extinguisher
kyle, go to hell.
new seals are in, axle is mostly back together. i'm not re-mounting the stupid disco stuff, i'm making a plate to cover it out of 11g. didn't have any luck finding any of the seals with 2.00" OD and something inside that fit the 30 shaft at napa or the local drivetrain place. tooooons of part numbers but it's all special order and wouldn't be there for a few days. oh well. i'll preorder next time the seals blow. i cleaned the long side shaft and greased the whole thing before i ever so gently installed it.
gonna go back out and do one more thing to the lower control arms and finish sealing up the 30 and cutting/drilling that little piece
my rig is all back together, rides great still got to adjust the draglink though
the seal i used for my disco to non conversion was a bit small on the axle side so i got one that fir the shaft just right and siliconed the poo out of the outside edge, works great i have no leaks
superlift 9/16 Ubolts showed up today, fri shoks should be in, also fri will be gettin a new rear axle wich i will clean up and paint, then it will go under the jeep on sun. i will also be installing a Detours backbone on a friends rig sun, too much shit goin on and to little time
i was busy making my white-board of to-do's :)
