I'm starting to wish that I had done this.
I'm starting to find little things that I hadn't seen up there. Like the steering box moves when you have someone turn the wheel side to side.
So I was working on the Jeep. I took the throttle body off and sprayed it down with some carb and choke cleaner. I then took out one of the spark plugs, but never fully put it back in. I ended up getting the Jeep to start on 5 cylinders, and idle for a second before I realized I left off a plug. Put it all back together and got it to idle perfectly fine for a couple minutes, then it died. turned it back on and it ran, I was able to move it, and I was going to pour seafoam in it, but it says do it with a warm engine. so I started giving it gas to warm it up, and then it now won't restart.
I did hear a clicking from a relay in the engine compartment, the fuel pump relay to be exact.
