Re: THe NAC Lots-O-Post Thread aka North America Home Owners Association Thread
Ok... Back to wiring. I verified I have to correct wire.. I think. 85 off of a relay is ground, that's the wire I have... But it's hot and when I ground it I blow the fuse. How does this shit work?
Like magnets.
I attempted to figure out WTF you're trying to do, but I'm not going back 3 pages of bullshit to figure it out.
So what are you trying to do?
30 is hot
85 is ground
86 is switch
87 is load
if you've got 12V on the 85 leg you've done it wrong, that should only be the ground for the coil that you energize on pin 86.
It's a switched ground relay I believe... I read on the rover forum to just add a ground to pin 85 to trigger the relay.
80k mile 6.0 with harness and ecm for $1000
complete wrecked 04 suburban 6.0, 4l80, 4wd and 14 bolt for $1000
140k 5.3 long block for $200
unknown 5.3 from sams pull a part for $300 (i think thats the going rate)
anyone wanna haul a suburban to my house?
could probably make most of my money back on that one.
$50 buys you a warranty on an engine at sams.
Show up, we jam the battery cables into an 18v cordless power tool battery pack to get odo mileage. Make sure to use an obviously crashed donor, I'm sure there will be one.
Chop exhaust, unbolt tranny, cut rad/PS/tranny hoses, loosen motor mount bolts, wad all the accessory BS and wiring up on top of the engine, unbolt bellhousing, untie some seatbelts through the manifold runners or motor mounts, call the loader operator out and have it dragged out and loaded onto the trailer. $316 with tax, if I'm there, usually. Hell last time I bought a motor they told me to grab a battery off the rack out front and go start the thing up before I started pulling it.
I buy enough shit there with little enough hassle/haggling/BS out of me that they basically let me do whatever the hell I want.
85 vs 86 shouldn't matter which is ground or which is "switch", it's just a coil.
Relax, if you're that worked up about answering his question go back and read the informative initial post, no need to be short with someone because you're too lazy to do a little looking around.
Unless it is a diode-snubbed relay coil (common in some makes), in which case it matters a lot. Been there done that, relay let out the smoke.
Adam, what you want to do is ground the ground side switched coil pin. I can't tell what K5-11 and K5-4 are. Measure the voltage on each pin when the fan is turned on by the ECU, then wire your ground to whichever one is grounded. Warning, depending on how sophisticated the ECU is it may throw a DTC relating to a circuit fault on the relay control circuit if you do this, in which case you need to add two diodes in a wired-AND configuration so each control circuit only sees what it is doing. Any 1N4001 through 1N4007 diode should be fine and they are cheap.
I'm guessing since grounding pin 85 blows the fuse, that is the hot side, in which case you should ground 86, but double check that.
Oh, and there will be 12V on both 85 and 86 when the relay isn't energized, because Ohms Law. The second the relay is energized one or the other will drop to near zero.
