THe NAC Lots-O-BFG KO2 Thread
Re: THe NAC Lots-O-Post Thread aka North America Home Owners Association Thread
Dumb, but I'll look if I go. Probably cost between $25-50.
They go for 75 new on eBay and the idiots on the reading post want that or more just trying to save a couple bucks
I'm actually right down the street from Everett's right now doing a truss job on a new Cumberland Farms.
i think i'll try and figure out that water temp gauge on the mustang after work, then maybe take it for a spin... see how hot it gets.
What motor? Any idea what its supposed to be at?
347 stroker... basically a 289 with no cylinder walls left. the PO said it should run at 165 but he was def on some sort of crack bc there is no way a motor that big inside a 65 mustang will run that cool with a factory size radiator.
My father stuffed a radiator from a New Yorker with all options into his challenger. Still doesn't cool the thing enough.
It's not a factory rad.. It's some thick aluminum one but it isn't large by any means.
Ross if you happen to go everetts this week wanna see if they have a tight front driveshaft still in a jeep? If so I'll go grab it this weekend.
I cant wait to get this pile together and destroy it in the woods
Rocktoberfest? Just follow me
Thats the plan, all the axle crap should be on order this week, already have the 3 link from Ruff and stiffeners, 44s are stripped and getting blasted. Should be ordering slider material next week then itll get cut up.
sweet, and you thought we were crazy at the wedding
so, someone learn me on switched ground. i want to add an override for the efans on the disco, but the relay is apparently switched ground.
i have this type of switch:
so it seems that i can just replace the 12v from the batt w a ground, and the 12v to the relay with a ground... right? my switch wont light up that way but i guess it isnt a big deal.
