So I finally got pictures of my garage.
It's 22 x 22 at the widest, and knocks down to 18ft wide after the little insets on each side. Each inset is about 80" long before it kicks in.
Just an overall shot looking from the garage doors towards the basement door. Shitty thing is I need to be able to keep lawn equipment in here too since we don't have a shed.
This is the corner in front of my MJ. Shows the size of the little inset. I plan on keeping this side mostly clear so I have more room to work. I think I'll end up keeping my toolbox and rolling cart up against the basement wall here. Probably one row of shelving above those for brake clean/glovves/rags and other stupid shit. Gonna junk his workbench since I have no use for it.
I think I'm going to build a workbench the length of the inset on this side. I'll probably make it about 6" deeper than the inset (total of 30" deep) so I can slide a 22' piece of tubing under the bench and have it ride along the wall all the way towards the garage door and not have it in the way of anything. Then I'll put my drill press/bandsaw/lathe up against the basement wall there.
Against the other wall where you can kind of see the ladder, I'm probably going to put a rack for steel and another for wood or something. Probably throw the steel rack on casters or something so I can keep it mobile. Open to ideas there.
This is the basement I finally cleaned out. Kate said I can store as much shit as I want in here as long as I don't setup my carport :laugh:.
Probably going to throw all of my bolts/wiring/bullshit in here as well as plumb the air compressor out to the garage. Most likely keep the tubing bender and whatnot in here as well just to keep more shit out of the garage.
