THe NAC Lots-O-BFG KO2 Thread
Just 2.
+ to the solenoid (small wire) and + to the motor (big wire).
That's it.
That's what I thought, but I was confused after just looking at a picture of a starter and seeing 3 places for wires to go. Last weekend I looked at rob's jeep for the first time, and I'm pretty sure the starter/solenoid is dead. I'm getting voltage at the two wires, but no crank. There is also like 1 inch or so of exposed wire on the big wire where it goes into the weird solenoid connector, so I'll probably replace that wire harness since I have spares.
I just want to get rid of that thing, then the Briarwood, and take over my dad's Cherokee.
Billy, still have that detours front bumper?
Bummer, I have to be in CT next Saturday, then plans for next Sunday. I haven't seen any of you ****ers in ages.
So I go to work yesterday morning - headlights work fine. Come out from work, no headlights. Drive home with my parking lights and fogs.
Investigate - connectors are fine. If i plug the bulb into the stock plug instead of my upgrade harness, bulb works fine.
Oh...what's this?
Well that could be why...it gets more interesting:
So... the power feed wires for my harness got crushed below the battery tray somehow enough to rub the insulation off the wires. The result was looks like it was a fun party as the wires arc welded themselves to my fender and burned the battery and tray. Well that could have gone worse....
should have the eff too fitty running again this weekend, gonna be brave and drive it to f&f on thurs
It was in the length of wire in between the battery and the fuse
i'm going to solder a bunch of fuses together to form a chain of safety in place of the wires.
Genius!
