THe NAC Lots-O-BFG KO2 Thread
And that's where the footage in the beginning of transformers came from
I'm glad i'm not the only one that was like "HAS THIS GUY NOT SEEN TRANSFORMERS!? IT'S ALL FIGURED OUT"
THe NAC Lots-O-Post Thread
Would a bad oil pump cause it to go between 25psi to 50psi?
Before you go suspecting anything check the pressure switch. Also if you're talking about fluctuations from idle and when you're driving, that's normal... I probably wouldn't worry about it either way.
Low of 19 and high above 40 is normal
FINALLY found out what was ****ing up my O2 sensor BS.
Fixed the drivers side collector flange and thats all set now but the O2 was still going nuts.
Turns out my pass side header hit the shock tower and cracked in a few places. Hard to see until I looked for it and pulled it out.
All welded up and I'm gonna put it all back together tomorrow. I love that my father and uncle stock up on 440 gaskets. Anything I need they already have :laugh:
Cmelo and h8pvmt thanks, I was a bit worried. 220k and still running good is good with me. My old 88 had 40-55 psi all the time.
Is it good or bad that I'm passing up the 4 38" boggers with great tread for $400 and instead saving for 42's I mean I could have the 38's tomorow
Kinda, but I like 42s :gee:
id say its good to pass them up.
I was just looking at interco's site what rim size are you going with?
it says 42 only roll on 20's
no you are making the right decision IMO.
16.5's keeping my stazworks
size it shows is 15/42-16.5
you should probably make sure someone has 4 in stock first
got 3 quotes, all say they gotta get drop shipped from interco, heres to hoping i get them before memorial weekend:cheers:
