XBoBJ
- Spencer MASS
ive done one that way before, was on a taurus though.
DOHC timing belts aren't bad at all. We can do my buddy's Miata in no time at all. Pull the valve cover and use a couple adjustable wrenches and a pair of vice grips to hold the cams and you're good to go. Don't even need the vice grips if you have two people.
Edit: Though the miata is a non-interference engine so that might be part of the reason why it's easy; not quite so important to keep the cams from moving.
