If you have any kind of aftermarket diff cover and plan on running the JKS steering, you won't have the room to run a straight TRE or heim joint. You need to put some kind of bend in the tie rod to use a straight end, or else you'll hit the diff cover.
The factory WJ ends are plenty beef at 24mm, and are cheap enough. They clear my ruffstuff cover until I just hit full lock left.
