THe NAC Lots-O-BFG KO2 Thread
and yes. thank you anthony :) I appreciate it. we'll call it a trade for the parking lot alignment help heheh
if you think that's even, sure. i still think i owe you.
Fine, still owe me. like it would bother me me hahah. Anyway, I think I asked ya before in whatever other thread, did you want to borrow my OBA for nacfest?
you can pick it up memorial day weekend :illegalflipoffsmile:
i should have mine all set by then. but thanks. i have a tank with all the fittings i need (i think). i just need a compressor and to wire it up and connect it.
I bought the kit because it was $15-20.
The box looks great and doesn't seem to have any play, and it was full of clean fluid. I was planning on drilling/tapping it for hydro (hence the need for rebuild), but decided an XJ box would work just as well.
so you dont think the box needs a rebuild... how hard is it to rebuild the box?
okey dokey. well its available if you want it, one less thing on the list ya know. I won't be using it for quite awhile anyway. I'm flipping a coin on whether or not to just cut the roof off now, in which case the oba's coming out; I don't want it out in the weather heh. When it's all said and done it will get remounted inside behind the seats. But for the time being, it'll just be sitting in my room :laugh3: so you're more than welcome to it
um probly just to freshen it up aaaand easy peasy...just takes time
we shall see. how good is it and what's the setup? don't you have a york? i still need the compressor.... how much do they go for?
adam, is your DW gone?
Worth the effort though, I would think.
nope, i have a VIAIR setup. I'll see if I can find it, gimme a min...
it should be when i replace the hub in an hour!!!
sweeeeeet
I lost the power wiring for it so for awhile I was just using 4ga wiring from my system haha. Worked great :D
shalamalacka.
jeeeeeeeeeeeeep
the tank i got from bump is bigger and all set minus the compressor... so i think i might just stick with that. gotta figure out what kind of compressor. i'd like to get a 12V but they all suck.
.XJ.
edit: post #8000 in the thread. teehhehehe yess.
