asp
- Westport, MA
or did what ross just said.
:huh:What the heck are you guys getting for gears? You guys are way overpaying for that, IMO. Even a high quality set of gears is $185-200, then $80-120 for a master overhaul and you as less than half the lowest cost either of you mentioned.
that's not runout if it's only off in one particular spot. it's flatness.
yeah, runout would be if the carrier was egg shaped out
Again...I'm including labor in the cost I'm posting.
I can't setup gears myself![]()
I should smack you, you can do it. Give yourself more credit.Thats nuts. I don't care who does it, that is a ripoff. Do it yourself or find someone who isn't being you over.
Colin, if you don't want to shell out tons of money on gear installs, and don't mind not having a warranty, I'm up for doing another HP44.
thank you geometric tolerancing.
Haha...I can hear my heartbeat in my ear.
those are the hubs? i imagine you're getting the ones on the right... let them soak in gasoline for a while. then look at how bad they really might be and regrease them.
