vetteboy
- morganville, nj
That sounds vaguely familiar...I know what I did was nothing more elaborate than de-soldering the mechanical pot and connecting those 3 leads to the circuit board.
I was the only mechanical engineer on the team, with the other 6 people being electrical. Somehow I ended up doing the bulk of the soldering after finding way too many cold joints and people learning the hard way that just becauase you can design a circuit doesn't mean you can build one. There was a lot of dead weight on that team and it led to people getting pissed when I'd just do their part anyway so I could move along with mine. The guy who was my roommate at the time was also on the team, and he actually knew his shit and was brilliant at programming, so that worked out well - we did nearly all the design work in our apartment.
Frankly there was no mechanical "engineering" involved at all in building the car itself (just a box tube frame with simple steering and the Rascal motor)...kinda funny how that works out.
I would be willing to bet a case of beer that your problem with the digital potentiometers was relative voltage - your control circuit and the circuit it was controlling were not on the same reference, and the digital potentiometer chip ended up sucking up the difference and going up in smoke. The problem is that the scooter controller probably used the original throttle pot on the high side of some circuit (i.e. tied to VCC/VDD) while your control circuit was trying to use it ground referenced :explosion
