vetteboy
- morganville, nj
You probably don't want to do what I did. It's a long story but I'm bored.
My XJ was 2wd, 5-speed from the factory. It had the external slave setup on the trans; being a '94 it had just changed over from the internal slave a few years prior.
When I did the initial 4x4 conversion, the transmission I ended up getting was a BA10/5 from a '89. I was a dumbass back then and got as far as bolting it up to the motor before realizing that the clutch was different. Meanwhile I had to drive it back to school the next day. Great planning.
The stock '94 clutch line is a molded rigid plastic piece that gets held in to the MC and SC by a roll pin w/O-ring. I chopped the slave cylinder end off and went to Lowes; and found a combination of a barbed fitting and flare adapter that I could hook up to the slave cylinder line. I jammed the barbed fitting into the clutch line (it didn't really fit), threw a hose clamp on it (which probably did nothing because it's rigid plastic), got the clutch bled and went on down the road.
So 7 years later
gag
, I still have that barbed fitting and flare adapter in there. The NV4500 swap uses the internal slave anyway so I never changed it. This came back to bite me in the ass last weekend at Big Dogs in VA when the clutch line got a hole in it and the master cylinder died, somehow simultaneously. Not knowing about the hole, I drove 50 miles round trip into town to buy a new master cylinder for the OEM application - '94, external slave. Because I still had the stock MC and roll pin/O-ring fitting, even though I've been running an internal slave. Got that swapped out and found the hole in the line when I went to bleed it. Awesome.
Turns out if you call the dealer for a clutch line for a '94 XJ, you have to talk to 3 people before you get someone that even knows that XJ's ever came with 5-speeds. Then they can't find a listing for the clutch line because it's only available as a complete kit - MC, line, SC. Well I don't need the MC because I just replaced it, I don't need the SC because I can't use it anyway. FML.
So I repaired the existing line with a brass compression union from Lowes (funny how these things come full circle). I had to mix and match two sizes; the line has a thick wall so it needed the inside sleeve for a 1/4" hose and the outside ferrule and fitting for 5/16". I cut about 3" out of the middle of the line and compression unioned it back together, and it seems to be holding up OK. If my prior experience with Lowes' brass fittings is any indication I don't expect to have an issue with it in the forseeable future.
Cliff notes: '94 XJ MC, '94 XJ clutch line, brass compression union, barbed hose fitting, pipe thread to flare adapter, '87-91 internal slave.
chris, what did you do for your clutch MC to SC line? I was thinking about getting the braided line from Novak for $50. I'm not sure I would trust flared hard lines coming off each cylinder with a small rubber piece inbetween to take up the flex.
So 7 years later
