- Rainy side of Washington
on hold for 20min now with insurance :gonnablow
24. Does DaimlerChrysler authorized the use of high-flow aftermarket air filters such as K&N with my Cummins engine?
No. DaimlerChrysler and Cummins do not recommend the use of increased flow air filters such as K&N, because they can allow contaminants into the intake that can ruin an engine (scoring the sides of the pistons, etc.)
So buy a hat. :doh::roflmao:
My left ear nearly froze off on my way home last night. Otherwise I would consider it![]()
So buy a hat. :doh:
And for mounting a bumper: Is there any reason why I couldn't run a unibody tie in bracket on the outside of the bumper mounting bracket rather than between the bumper mount bracket and the unibody?
I would have to create a spacer which would fill the gap behind the bumper mount, but otherwise, any real downsides to running it on the outside and sandwiching the bumper mount and spacer between the tie in bracket and unibody rather than the other way around?
If the bumper mounts are welded onto the bumper and are relatively tight against the unibody (so I could not fit the tie in's between the bumper mount and unibody). Trying to find work-arounds.You'd be creating more work for yourself. What's the benefit?
hmmmmm what else do I need from summit racing before I click submit
Good idea! I can list a bunch of small stuff Ken needs from my XJ.anything small you want shipped for free
I keep forgetting to pick up that back seat but other than that I can't think of anything :eyes:Good idea! I can list a bunch of small stuff Ken needs from my XJ.![]()
Haha! That was supposed to read "for" not "from", but either way how does $347.87 sound for a slightly used lugnut? I can have it sent via overnight for that price as well.I keep forgetting to pick up that back seat but other than that I can't think of anything :eyes:
I guess I'll buy a lugnut though, how much will shipping be to 01602?
Price sounds great, I can't find any change in my monopoly set though so I'll send $350Haha! That was supposed to read "for" not "from", but either way how does $347.87 sound for a slightly used lugnut? I can have it sent via overnight for that price as well.
If you want stuff "for" my XJ, it'll be significantly cheaper.
What are you getting from SummitRacing? Wheels?
MORNIN NAC!
I'm thinkin' for Christmas i want a Nikon D40 or D60? Any suggestions? Lenses, Accessories, etc. HELP ME OUT DUDES!!!
So I did a little researching.
4.0L fully dressed weighs about 515 lbs.
440 fully dressed weighs about 580 lbs.
I can give up ~70 lbs![]()
Edit: Reason is, I am looking at buying bump's winch bumper & it looks like it only uses the stock mounting locations (http://naxja.org/forum/showthread.php?t=1017527&page=2). I am not sure how the mount brackets are spaced on that bumper, so in the event that they are tight against the unibody I may have to find some other way to incorporate a tie in.
hmmmmm what else do I need from summit racing before I click submit (I expect hilarious ricer gear responses)
Wow, you got a set of 36s or 37s you want to part with cheap?By the way I just counted 49 tires in my corrall and thats not counting any on vehicles.
EDIT: Jeff, I still have your bumper caps + stock towhook brackets and such. I'm hoping I can pass them to you via Kyle whenever I get him his beer, failing that, I may just head for Stoughton in a few days.
