asp
- Westport, MA
refresh my memory. 4 door is the big jeep? (assuming little jeep doesn't have locking hubs...) i say check your front driveshaft for balance...
Funny, I've had the same thing happen with my SYE.it makes sense that it could be that. my output yoke on my SYE came a little loose not that long ago and it was causing some vibes...
It's been a while, I can't remember what I did when I put it back together. I found it loose when I was pulling the drivetrain after the fire. While it was out I ended up tearing down the case and installing new output bearings, output seals, fork pads, and a good cleaning. I think I might have loctited it.i'm tempted to take the nut all the way off, clean the threads with alcohol or something and and put a low strength loctite on.
it would make sense for it to be loose after a fire. i bet the little seal in there melted right away.
so my boss volunteered his tires for the M&G i have no idea what they are but he said they are better than mine...
woot i might not get really stuck!
how bad are your truxus? there suposed to be real good in the snow
BFG ATs FTW!
