ftwelder
- Rockinham, Vermont
I got my '94 XJ 4dr. about a year ago. It was easy to own at $500 and I figured we could use a 4X4 on our wood lot. We used to van-camp quite a bit and with the kids out of the house, no need for a back seat or extra room. The truck came with a the 4.0/AX15 combo, a 3" OME lift and had been pretty well maintained over it's long life. The bad was severe rust holes and a couple of dicey repairs on the door hinges and blower motor. The truck had been painted OD green and had a DIY bumper/tire carrier and at one point had almost lost it's top to a sawzall as there is a cut about 1/2" long on the rear corner.
I have a little welding shop and specialize in making bicycle frames. I don't know much about jeeps but since getting this one I have been doing a lot of research. I know I have made a lot of mistakes but the road is a long one and it is what it is. On a side note, I know it takes a lot of work to produce a quality thread (not my strong point) and most any quality you do find below will have come from builders before me on
and also the fine book "the ultimate Jeep cherokee book" by Eric Zappe. Thanks to all of you in other words.
I don't have an indoor spot to keep the vehicle and I don't always have money buy things but I do have lots of machines and materials and as you know there are so many things to be done. Onward
The first thing I did was try to go wheeling. It had 29" tires and stock 3/1 axle ratios and didn't seem to go slow enough and had this weird "rocking" thing when you let the clutch out, it felt like everything in the drive train was loose so I bought some stock motor mounts then woops..
I let go of the wheel for a moment on the way to work (I live on a nasty road) and the vehicle made a hard right and I ended up in a ditch with my headlights touching the ground. I sort of panicked and went WOT and started banging the shifters and some how ended up back on the road. I pulled over and one of my front tires was about 3" too far back. :doh:
I got to work and took a quick look underneath and noted LCA brackets were buckled. the lady across the street was selling her ZJ for $700 so I bought it and and put the XJ on stands with the intent of fabbing a new bracket and moving on.
I worked on offroad cars twenty five years ago and at took a while to grasp the scope of work that had been done since then. I did far too little research and sitting there with the front wheels off I started thinking since the axle would come out to replace the control arms and axle brackets I may as well do some upgrades. I started drawing the basic suspension geometry in autocad to see what was going on. I had seen some hack drop brackets in my searching and noticed I had spacers above my coil springs so opted to relocate the LCA axle brackets higher rather than lowering the rears and about 10 mins later had researching pushing the axle forward to put the spring directly over the axle. After computer foreplay I came to the conclusion that I would need to also relocate everything but It was a nice spring day about a year ago and I felt like welding.
30 161 by barnstormerbikes, on Flickr
30 162 by barnstormerbikes, on Flickr
30 160 by barnstormerbikes, on Flickr
