The issue with the rear quarter panel guards is you are adding strength to the spot that gets hit every time you drop off a rock, then sending the impact up to the top corner of the rig.
You end up needing hatch plates after a short time:
It is best to cut that part off and build a bumper to take the hit, not put the impact into the body.
Check out Mr. Ed's new rear bumper that Jes built, he has added clearance and some good body protection.
