The length of the control arms will be shortened on the rear and it is sitting at full stuff, I plan to raise the rear upper shock mounts also to even it out so that I will have equal up travel on both ends, the front axle looks way forward but I still need to add a front winch mount and small stinger which will change the look of the axle placement also, the whole engine has been moved back 14" from what a stock cherokee would be to even out the weight distribution. When I built the box tube frame I went off the topside measurements and angles of the Cherokee unibody rails in order to keep the necessary mounting posistions of the 4.0 and AW4 trans, it looks odd because I used 2" x 3" 3/16" wall tube.
