GScott
- North Carolina
scorpio_vette said:i didn't feel like reading the other comments, so i don't know if this has been said or not. turn the little spring on the front of the fan clutch 90degrees counterclockwise. if the temps stays normal at that point, then the clutch is bad and needs to be replaced. (from factory service manual)
can you explain a little more about this test?
