Test Pic
2xtreme
Kayak Pt, WA
Just a red X. JIM.
Can someone tell me what I am doing wrong??
Thanks,
Michael
Thanks,
Tells you how often I post pic's. They used to host so that I could post them just fine (probably been well over a year or two).
Thanks again,
Michael
OK, I have now switched to Photobucket.com. With any luck this should all work now.
So, it does now work. but how do I get larger pic's? Is this just the program and no choices?
Thanks for all the help,
Michael
You will have to upload a bigger pic on photobucket. After you put the pics on there you can shrink them down, but be careful... after you shrink 'em you cant make 'em bigger without re-uploading the pic agian.
Edit Picture
help Tag or Title
* Warning: Changing the picture name
will break your direct links
Resize Picture
O 75% of original
O 50% of original
O 25% of original
* Warning: Once you reduce a picture,
you cannot enlarge it back to the original size
Rotate Picture
O Rotate 90%
O Rotate 180%
O Rotate 270%
* All rotations are clockwise
