tera control arms / r.e. drop brackets etc.
tow_hook
western pa
tera flex gen 1 control arms uppers and lowers: fits any tj/xj/zj/mj, the lower arms need front bushings 5$ each at tera flex. 300$ for the set of 4, the upper are 200$ new pics avl
rubicon express xj drop brackets with braces: painted with hardware. asking 250$ new 350$ pics avl
denman ground hawg tire: 40-17-15 brand new, never on the road. used as a coffee table no cracks, no dry rot. make a offer pics avl
2" lift blocks: make offer
3" lift blocks with bump stops ( off a full size bronco ): make offer
1" drop xj drop pitman arm: make offer
i live near pittsburg pa, i do travel to the eastern part of the state once a month. any questions about meeting half way p/m me. we will see were 1/2 way is.
forgot these items
2 rancho 5000rs shocks part# rs5012 hole to hole style 32.5" open 19" closed 50$ needs lower bushings, bushings do have some slop
93-94" cruise control unit ( the pump and cable to throttle body from undwer the hood) 10$
xj "steel tank" fuel pump $10
u-haul trailer wiring kit fits all models $10
ipf rear back up light, used, with all wires, turn on switch button missing. 50$
http://www.quadratec.com/products/97017_1200.htm
