I recently changed the Waterpump, Thermostat, and Serpentine Belt. The thermostat is the factory 195f unit with the check ball and hole in the 12:00 position. The temperature shows 210f and then drops to 150f back forth as I drive. Been about 2 weeks of this. I assume I got air in the system and need to burp it.
What size hex is the Temperature Sending Unit and how is it removed? I tried to get deep wall socket on this Unit and and I can't get the socket to fit the hex since the Unit is right up against the Valve Cover. Do I need to use a Crows Foot Wrench?
Thanks for your help.
96 4.0
96 4.0
