Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Most exhaust system back pressure problems are in the cat or muffler or after the cat.
With the O2 sensor pulled or disconnected it should run rich, ECU/PCM computer open loop mode, but have plenty of power and idle and run perfectly, and run cooler if nothing else is wrong. Open loop mode is gas guzzling mode. Great diagnostic mode!
Lack of a working O2 sensor will damage the Cat over time by overheating it due to to much excess fuel in the exhaust.
The second O2 sensor only confirms Cat operation and is designed to force you replace the Cat when it dies. Tha is all it does. It also confirms the first O2 sensor to some extend, but does not affect engine management.
MAP sensors are pretty much bullet proof, almost never fail, so your Map sensor failures are very non typical! I would suspect the vac line going to it or the wiring going to it! Map sensor is the only one sensitive to air pressure.
WildernessJeep said:Okay, assuming I cut the pipe just in front of the cat, two things:
1) That still leaves open the option that something upstream is clogging the exhaust. Specifically, this exhaust has the "factory error" in it with the pinch just above the flange. What are the chances of something up there clogging the system around the flange?
2) Isn't the lack of the second 02 sensor input really going to foul up the engine computer?? I know it would over time, but would I be able to diagnose an overheating engine with the computer in default? How long would it take for the lack of a second sensor to disrupt the computer to the point of non-performance?
3) What other sensors are prone to fluctuations in air pressure? The MAP sensor I know, but what others?? It could be the engine is running overly rich due to another mis-reading sensor (which also could be destroying the MAP sensor).
Opinions???
