BigRedsXJ
- california
crashed my jeep and fixed many things,
rear leaf spring, rear driveshaft yoke, r driveshaft ujoints, COMPLETE FRONT AXLE (housing and shaft were bent) rims/tires
when the front d-shaft is disconnected from the front axle and you turn it, it makes a clanking noise in the t-case, what could be causing it?
also the tcase is leaking very bad from the back where the r driveshaft goes in, how far is that yoke supposed to be on the splines in park ? mine seems like its only on maybe 1 1/2 - 2 inches. will a sye help (stock jeep not lifted)? ive had the rear seal replaced on the tcase only to drive home and find it was leaking severly again.
this is my DD and i reallllllllly need to fix it, please any input will help
(98 xj 4.0 4x4)
(98 xj 4.0 4x4)
