RollinCoal02
- Green Bay, WI
I just acquired a 95 XJ crawler/mudder from my cousin. The clutch fan is going out so i started googling solutions. i ended up buying a Taurus fan and a 100A continuous relay for the high speed. I also tried looking for wiring help but couldnt find what i was looking for. so here is my question
1. Can i wire the low speed on the Taurus fan to the auxiliary fan. so when the Aux fan kicks in the Low speed kicks in. then wire the High speed to a toggle?
2. OR could i wire the low speed to a ignition source so when the jeep is turned on the fan would start. then wire the High speed to the Auxiliary so when it gets warm it will have the extra cooling automatically when it needs it.
I like option 2 but i would assume you would need to shut off the low speed power when high speed kicks in? Any wiring experts out there to give me some direction before i go burning the jeep to the ground:flame:
