pjanda1
- Boulder, CO
Hi guys,
I recently pulled the motor (only 130k miles) to replace a leaking rear freeze plug, and while I was at it, I did the rear main seal and oil pump, among other things. It worked great for 100 miles or so. Then, one day when it had run for quite awhile, I started hearing what I thought was a knock from the crankcase. It sounded like it was coming from the back of the oil pan.
So, I pulled the pan and checked everything. It all looked fine. One side of the rear main may have been a little bit under torque. Or maybe it wasn't. But the bearing looked great, so I put it back together. I didn't trust it as much this time. I let it idle for an hour and get up to temp. Dead. Silent.
And then I drove it around on some errands, and the noise is back! It sounds more like a tap than a knock. Changes with RPM, probably once a crank or cam revolution, though it doesn't get louder, so it gets harder to hear.
I'd take it apart again, but I really don't have any guesses about what is going on.
Thoughts?
Paul
Thoughts?
Paul
