Simple Man
NAXJA Member #979
- Nevada
I’m planning a short work day on the Tahoe side for Saturday September 24th. Yes, it this next weekend.
In short it will be a day of moving logs.
The first project is right in the staging area. We need to remark the boundary of the staging area parking lot. There have been instances of people parking on vegetation. There are logs in the area that can be moved in to place with winches and tow straps.
The second project is at Miller Lake. The forest service has agreed to drop a few trees to help block the bypasses in the area. We will need to block the trail while the trees are being dropped and then drag the trees in to place.
The third project is at the large mud hole just west of Bottom Dollar Hole and The Potato Patch. Again we need drag logs in to place to block the bypasses in the area. This spot is about one mile off Barker Pass Road.
The Fourth spot is another mud hole about two miles from Barker Pass Road. This time we need to block the original trail and reroute traffic along on of the bypasses. The original trail goes through a mud bog while the bypass stays on high ground. Again, we will use existing downed logs to block the trail and reroute traffic.
I know it sounds like a lot but we will take on what ever we have the personnel to accomplish. There will only be room for about two vehicles at each area (except for the staging area).
Post up if you can make it.
Saturday the 24th 9am at the Tahoe staging area.
Doug Barr
Doug Barr
