Begster
- Cape Cod/Boston, Mass
but before dropping a huge skid plate an inch and hogging unnessesary ground clearance. why not run an sye?
X2
you can clear a t-case drop with it, just drill the holes in the rails lower.
but before dropping a huge skid plate an inch and hogging unnecessary ground clearance. why not run an sye?
Look at J B Conversions. upgrade internals at same time.
uh doesnt every skid cover from rail to rail? :doh:It is not much that you loose and it covers from rail to rail which allows me to glide over things
If you have the 242, then you only have the option of a "Hack & Tap" SYE, available from Rubicon Express.
No. Most don't actually.
I have DPG and it works well. I may modify it a little in the near future to gain some clearance.
Out of curiosity, how would you modify it to gain clearance? I think the only thing you could do would be to bend it a little closer to the angled portions of the stock crossmember, but you'd probably need a pretty substantial brake to accomplish that. Dont really think it would be worth it.
Cut the stock crossmember and weld the skid to it. Something similar to this except I would have to cut and redrill the holes on the ears to make it work.
I have a 99 with a SYE and a TC drop. But from what I just read I cannot use either of these skids because you cant use TC drops with them?
