Brendan_91XJ
NAXJA Member #1163
- Long Beach, CA
Thanks
Q: When installing the shims, does the bottom of the centerpin need to go through the shim and sit in the spring plate on the axle?
random pic, but you get the idea. the angle depends on the degree you want it at
http://www.4crawler.com/4x4/ForSale/Images/Shim10.jpg
did you run any of these when you swapped out to the dana44? if so what degree shims did you use?
I'm not sure. I'm running Deaver leaf springs and they came with the shim built in. So I dont know what degree they are. Anyways, they broke off and fell out in BB. So. . . :roflmao:
i wonder why?????????
. . . maybe 'cause I'm a THUG . . . :dunno:
or maybe cause you drive with a lead foot ...:rof:
I'll put my XJ against your XJ anytime, son. :kissyou:
calm down tough guy... this aint a pissing contest...
You're right. This isn't a contest. :smoker:
Yes Brendan the shims do get mounted to the spring packs, and yeah you should change the center pins, cause the old ones will most likly be too short. FYI have a couple of C clamps and a Drift Pin ready for when you take apart your leafs. Also once you get the shims in look at your lower shock mounts, and see how much of a bind they are in now. I ended up bending a set of shocks, and had to reposition the lower mounts.
