Kychaindrive
- Louisville,Ky
Ok guys seems nobody can figure out a better, perfect fit junk yard DS to use other than a stock front. Well I used a 90's ford explorer front shaft along with this yoke. The shaft is larger dia. & bolts right in. Make sure you get the shaft before you cut the splines so you can calculate the right amount of slip.
I'v used this setup on my 94 XJ, 5.5 lift, 35's, 44 welded, trail rig for over 2 years with no problems.
I also installed the same shit on a 99 XJ DD w/4.5 lift over a year ago, & the dude loves it, "no vibes".
