iwannadie
- Gilbert, Az
So, I went to ride today and haven't been out in a few months and I had Zero power not even enough to try and power the lights, horn it was like there was no battery. I hit it with a multi meter and was getting 10.x volts...
I pulled the battery out and it was really swollen, I am not sure how to describe it. The battery seems to have sections and each sections was swollen out on both sides badly, like ridges. No leaks or anything exploded that I can see luckily.
Now my question, it is a yuasa(YTX9-BS sealed date 2006) battery and I have used a yuasa battery tender(I forget the model info off hand but it is there smart shot tender or something) since day 1. I was told the battery tender was the way to go since I don't ride for long stretches and to just get home and plug it in so the battery never goes flat.
Was the tender over charging and causing it to swell up the way it is? I was told and read that the tender has stages of charging and cycles to prevent over charging. Or, could the swelling have just come with age and being in the AZ heat?
I hate to buy a brand new battery and use the tender if it is going to cause the swelling, I don't want a battery to explode on me :scared: .
