jeeptec
- atascadero california
for those of you who have done the over the knuckle steering conversion. are you running a sway bar?
I run the IRO otk system and i did not cut my mounts
Dont believe i didnt cut them?post pics
Thats only because they build a tie-rod with bent ends. I built my own for my old WJ knuckle set-up it was a PITA to set the toe-in properly since one end must be removed from the knuckle in order to make any adjustments.....and once the heims loosened up if flopped around like crazy.I run the IRO otk system and i did not cut my mounts
