AZRockRunner
Nobody
- Tucson, Az
I bought a used axle from a friend that already had matching gears and custom diff cover and lower control arm guards welded on. I have this axle installed finally but noticed that he cut off the sway bar links that were part of the axle. My question is, can I just cut off mine from my old D30 and weld them on? Should I leave them off and run with out one.
This is NOT a daily driver. Running Rustys 4.5lift with 32x1150R15 cable disco in front locked and limited slip ford 8.8 rear.
I am not planning on trailoring it yet, until it wont pass smog anymore. But to the trails is the only pavement it will see.
Thanks in advance.
Thanks in advance.
