Suspension shop info-Naperville, iL. area
pakkman
napervill, il
I am need of near rear end gears, lockers and axles for a 99 XJ etc, does anyone know of a solid local shop around the area of naperville, IL that can do the work? I tried aedofab, but they never answer their phone and I am unable to reach anyone. Thank you
Moved to the Midwest Chapter for you - they will probably have more detailed knowledge of local shops than the OEM tech forum. Good luck :thumbup:
McHenry 4WD, or Altitude Performance in Des Plaines.
If you can get to Fort Wayne, IN I can get you taken care of.
mac 'but that's not close' gyvr
Cool, I had talked to Mike a few months back at aedofab, but couldn't get a hold of him recently so thanks for the info, I will try again. We had talked about him doing lockers front and rear, axles with new tom wood rear drive shaft etc. probably needs all the u-joints done and maybe the upper/ lower ball joints. its a 99 stock XJ limited with 166K. The rear diff is a d35 with 3.55 gears that are shot and although the d35 is hated, this jeep will stay stock and lives on the street mostly, but i wnat to be set if I ever need it or want to go on the trails etc.
