xxmidianxx
- Spring, Tx
Yeah if they are set at the proper angle, it should only net you 3/4" of lift. You will get more up travel too if you cut off the "back two holes". JR said when he is compressed the shackle is even with the leaf pack. And looking at my shackles mounted on the brackets... I can see what he means and it seems to give you about another 2" of swing travel backwards. But I also have 2" lift shackles that are a little longer.
