cnidy1230 said:
the easiest way to increase boost i found is pulley size. many people have done it on the exterra and i guess get a good increase in boost. i will see, alot of brackets and fab work to do still. still in the research stage of this project.
Correct - what you're doing is changing the ratio of crank drive speed to snout driven speed - and you're usually driving it faster to make more boost.
We do have an advantage in that the AMC242 actually likes being run at relatively low crankshaft speeds (mine
lives at about 2800rpm!) and that means you're probably not going to end up "overdriving" the blower. However, since it's also a relatively large engine (over 200cid,) you may just want to think about getting the next size larger blower - like the Eaton off of a T-Bird or a Bonneville (~3.8 litre V6, should be the next blower up from that on a ~3.0 litre V6. 230-ish cubic inches, vice 170-ish.)
Also, the headache you tend to run into at higher boost levels (higher speeds) is "internal leakage" - where the compressed air actually ends up leaking backwards past the rotor tips and ends. This is a variety of "parasitic drag" that you may end up having to account for - and why it's better to use a larger blower, driven slower; than to use a smaller blower, driven faster. Ditto pretty much anything - always remember, TANSTAAFL ("There Ain't No Such Thing As A Free Lunch" - Robert A. Heinlein,
The Moon is a Harsh Mistress.) You have to be ready to trade one thing for another - the more you want, the more you have to trade.
I'd be perfectly willing to help you figure out how to get where you want to go - I've got most books on performance at hand (including one I wrote myself!) and I've got some decent sim software and I've already done most of the research into performance parts for you. Frankly, I'd have damn near
killed to have someone like me handy when I was building bracket engines, and had to figure all of this stuff out on my own! You can't get too much help or too much information on a project like this - you can aways just write it down for another project if you don't end up using it for this one. That's how I learned most of what I know...
5-90
