2000 Limited, 4.0, NP242, currently in need of a wash.
Here's the problem: sometimes, after stopping for a few minutes with the engine at normal temperature, I'll restart the vehicle and have a really bad stumble that feels like the timing's off. Power surges under acceleration, rough idle, sometimes you can make it misfire if you stomp the accelerator.
It looks like this may be linked to coolant temperature. If I park with the needle on the coolant temperature gauge at 210degF, switch off, and come back a few minutes later, the gauge will be reading above that - usually at or just a hair over the first mark past 210; this leads me to believe that heat from the engine block is transferring back into the coolant. If I let it idle until the temperature is back at 210degF, there's no problem. This is only an issue if the temperature's above 210 when starting.
I'm thinking that the block and/or radiator coolant temperature sensors are having issues, but was wondering if anyone else might have any ideas. The XJ runs fine otherwise, has good coolant (still green after nine months in there), and isn't exhibiting any other odd behaviour.
