CRASH
- Foresthill, CA
I have done some significant consolidation around the shop and have found some parts that may be of value to other folks:
Bored Renix TB. 58 mm (stock=52mm). Includes all sensors, runs very well, excellent idle stability. $100.
24 lb/hr Ford injectors: Used 10k miles, set of six, plus a spare. $60
87-90 Renix ECMs. Two units, both 1987. $20 each
91 and 95 OBD I ECM's. $20 each
95 Gage Cluster. $20
87 60 amp and 89 90 amp alternators. One has a pulley for use with both a serpentine to drive the alt. plus a v-belt for a Ford air compressor. Stock = $20 90 amp with fancy pulley = $50
88 Fuel tank. Virgin. $20
88 Fuel pump assembly + spare pump: $20
All items in Foresthill, can be delivered along Hwy 80 corridor. email is best: a j f e c k o a t g m a i l . c o m
