moparjim1987
- pennsylvania
my 97 cherokee is stumbling when it gets into second gear when you pull out. if you goose the throttle, it quits, but after you drive for a while then shut it off, it does it again. i've replaced the tps and the evap canister purge solenoid and it still does it. I haven't messed with the fuel strainer and there's no fuel filter to change. i need help because this is getting expensive.
